SunRunLandYacht
WonderYonder
Bring your helper, tester & truck or trailer, I will not ship, PICK UP ONLY!
Scammers - no Western Union or excess check crap!!!
SPECIFICATIONS:
Module Efficiency = 20.70% - Wow! – close to 21%
Open circuit voltage (Voc) = 50.5v+/-3%Module Efficiency = 20.70% - Wow! – close to 21%
Max power current (Imp) = 10.69a+/-3%
Max power voltage (Vmp) = 42.1v+/-3%
Short circuit current = 11.58a
Weigh 61.73 pounds ea.
Size = 82.44”L x 40.87”w
There is a 10th cracked panel included at no charge. According to the internet the cracked panel can be repaired with a thin plastic film or two part epoxy sold at solar panel stores to keep moisture out. After the repair, the damage is cosmetic and the panel will operate properly. The 10 - 450watt panel array will be capable of producing up to 4,500watts. Use the 10th panel as long as it last; (might be interesting test), after all its free.
This is not a scam. I purchased these panels fully expecting to use them myself but because of unforeseen medical issues and an unexpected move, my loss can be your gain. I have over $2,000 invested in these panels and you can practically steal them at ONLY .37 cents per watt. (Not including the free panel, then it's only .33 per watt. I will provide any information I can and will make whatever arrangements necessary for this to be a safe transaction for both of us.
All panels have been tested and are working properly but bring your meter to verify.
Thanks
