Greetings, what do you all think? 24 volt system, 3 panels wired in parallel. This comes out to 64.8Volts with 18 amps so the 50/100 MPPT is sufficient correct? Any other ideas welcome and helps out a noob in need of reassurance
STC Power Rating 320W
PTC Power Rating 294.8W 1
STC Power per unit of area 18.2W/ft2 (196.2W/m2)
Peak Efficiency 19.62%
Power Tolerances -3%/+5%
Number of Cells 96
Imp 5.86A
Vmp 54.7V
Isc 6.24A
Voc 64.8V
NOCT 45°C
Temp. Coefficient of Power -0.38%/K
Temp. Coefficient of Voltage -0.177V/K
Series Fuse Rating 15A
Maximum System Voltage 600V
--Victron Energy SmartSolar MPPT 100/50 Solar Charge Controller
--150Ah 24volt batteries/daly BMS
--Giandel 2000W Pure Sine Wave Power Inverter
Greatly appreciate anyone that can confirm my math on this one, love the forum thanks will and everyone that helps out!!!
--3 320watt panels in parallelSTC Power Rating 320W
Number of Cells 96
Imp 5.86A
Vmp 54.7V
Isc 6.24A
Voc 64.8V
NOCT 45°C
