SOK uses Pace and I have 15 - 100Ah SOK rack batteries. I've seen a couple others, but I'm used to the Pace. And I've figured how running a pack up to "protection" then opening it's breaker, the BMS will continue to balance undisturbed until it hits it's set release value 3.38v. Normally it would stop charging and balance, but if a cloud goes by, discharge starts and breaks balancing.
I ran that pack down to the cut-off then recharged with 38mV difference ?(not sure how much the BMS balanced, the Heltec was off). My charger was set to 15A max, so it took awhile and I wasn't watching when it finished.
I wish I knew how to network 32 batteries on the new Pace, their software shows it, but I still only have 4 dip switches.
And I ran the voltage up over 3.45 because the deviation became wider and I temporally had the Heltec attached.
