I was curious about this 4 cell active balancer board. It has 4 transformers so it seems to be a stack balancer transforming the cell voltage back to the overall assembly voltage.
Tested a slightly unbalanced 280 ah 4 cell pack and it seems to work, some voltage came down and others went up.
So the question is how does it work under the coating.
Decided to sacrifice a unit for knowledge and scraped the coating.
See pic..
The transformer has three windings.
Below the transformer are two MOSFETs A07T. Then the circuits in front are same components.
The large component is an option coupler El3H7.
Above that a KL3 3 pin.
Above that and directly below the inducter is diode K14.
Then on the left next to the white connector.
A mystery chip C3J0.
Above the silver selector switch are two
7002 MOSFETs.
It looks like the pattern of the black coating is all the same..
That would mean that the control is in the mystery chip.
Any suggestions / interest.
johan
See pic..
7002 MOSFETs.
johan
