Tulex
Solar Wizard
I've got 3 304ah batteries with Seplos V2 BMSs (passive balancing) below my inverter. They run individually to a busbar, then using both breakers in my Sol-Ark 15k to connect the inverter to the busbar. The 3 batteries are connect via comms, and the master battery connected to the inverter. These batteries are side by side, the cables are fairly close to the same length going to the busbar.
I want to add 3 more batteries, most likely made from 280ah cells. But, they have to be a few more feet away, and will have to be stacked, going almost from ceiling to floor. I know I have to stay with the V2 BMS to connect them all together. My main question is, can I run these 3 batteries to a busbar at the batteries, then connect that busbar to the existing busbar? I mean, I know that will work, but is that the best way?
