OG Dave
Hello everyone!
I do astrophotography as a hobby and intend to use my Ecoflow River 2 Pro to power my observatory rather than run A/C out to the back yard. My maximum load will be around 95W and 13.5A. I will be using 2 A/C outputs. The Ecoflow will give me about 5-6 hours at that load, but I'd like to add a 50AH or 100AH LiFEPo4 battery to the PV input, adding battery capacity.
My imaging setup is fully automated and once I start an imaging session, it runs the plan overnight and parks the telescope. I want to ensure the Ecoflow provides power until I get up in the morning to shut everything down. So I'm looking for about 10 hours of runtime.
So, my questions are:
Can I just hook the extra battery directly to the Ecoflow via the XT60 PV connector? (12ga ring terminals to XT60)
Should I fuse the connection?
It can get cold some nights - will this negatively affect the battery efficiency? (e.g. Do I need a heated battery with low temp sensors?)
Should I go with the 50AH or 100AH?
Thanks for your help!
Dave
Dave
