jor_tucson
Just want to make certain my figuring is correct. I just installed 800 watts on my RV with 4 Rich Solar 200 watt panels in a series parallel-configuration.
I call them S1 and S2. The 10 gauge wire from these is paralleled in a combiner box on the roof. Everything works fine. Now I would like to add two 100 watt panels in a series-parallel configuration and run that to my combiner box.
S1 and S2 at the combiner box are the same with 40.8v and 9.8a each so my current setup is 40.8v and 19.6a to my controller.
S3 at the combiner box will be 43v and 4.54a.
So... in that these three are paralleled at the box I use the lowest voltage number which is the original 40.8 and add the 4.54 amps so my new numbers are 40.8 and 24.14. Have I got this right? Thanks.
