joelspangler
Sorry if the answers to these are obvious, but I'm a newb. Looking to add a 10-12kw solar array with batteries to take part of my home off-grid, and avoid some of the hoops to jump through to export to the grid. I don't think this system will be large enough to handle my 30 ton heat pump, and things like my electric water heater, and stove. Here in PA, production will vary greatly from Summer to Winter, and I would probably want to run more of my home off of solar during the summer months (and less during the winter).
1 - How would one accomplish adding/removing loads to match production at a certain time of year? Would I need to manually move breakers from my "off grid" panel, to the grid tied one, or is there a way to automate or at least make it easier than moving breakers?
2 - I'd probably want to run even less stuff during grid outages - again is there a way to automate this, or would I need to go turn off certain breakers during grid outages?
3 - I've been trying to decide if I'd want my batteries inside or in my garage. I'm thinking of something like a short rack of lithium server rack batteries. I know they don't operate in cold well, and I'd need units with built in heaters. How much of a power load does it take to keep batteries warm enough to operate when it's below freezing? I know lithium batteries sometimes do catch on fire - how much of a concern is this? Should I be concerned about putting batteries inside my home?
