Hi,
I currently have 200 AH of Battle Born batteries and two 200 watt Rich solar panels, using a cheapo Renogy PWM charger, I went with this charger for cost, and the fact that it fits into the panel on my Jayco trailer where they would normally put their GoPower charger. My experience last year showed that 200 AH is not enough, given my residential fridge and the power demands of running fans on hot days, furnace on cool nights, etc. I'm planning to add another 100 AH battery to the mix, and am considering the following:
Thoughts?
- Replace the PWM charger with the Renogy DCC50S MPPT combination unit.
- Running the necessary cable (probably 1/0) from my truck battery (it's a long truck), where I have well over 300 amps of charging current available, thanks to dual heavy duty alternators on my F350 with snow plow/camping package.
- Adding an additional Rich 200 watt panel, running parallel solar connector and sets of cables down to the DCC50S, so as to not overload the existing 12 gauge wiring that Jayco used when they pre-wired for solar.
Thoughts?
