Flatpicker
I have a Sungold 8 kW split phase inverter with 10 kW (soon to be 20 kW) of wallmount batteries. Two EcoWorthy dual axis mounts with a total of four 560 Watt bifacial cells wired in series. VOC for each panel is 50 volts. Total string voltage when connected to the inverter varies between 160 to 180 volts. This string is wired into one of two MPPT inputs. Maximum voltage in on the inverter is 500. I’m not sure, but I think the inverter won’t even “break-over” and function unless it sees at least 125 volts. I plan to add another four identical panels in the future.
My question is this: If I add another four panels, is one way more efficient than another? Do I place them in series with the existing arrays for a voltage of 320 to 360 volts, or do I place the four panels on the other MPPT input? Does a higher voltage boost efficiency of the inverter? Does it even matter? Thanks!
