Advice needed.
LarryF
Hello Everyone looking for some advice on wiring up my solar panels, to maximize efficiency. I have 3 -370 watt solars panels, a victron 150/35 SCC, 2-100 AMP Li-time batteries. I currently have them wired in series. Attached is a photo of the panel specs. Any advice would be appreciated. Thanks
12V or 24V system?
If 12V, 150/35 will deliver 14.4V * 35A = 504W max, so you're over-paneled by almost 100%.
If 24V, you're good.
Thank you, I have it configured as a 12 volt system, previously had it as a 24 volt system. I’m researching the 2 systems to decide which is better for my camper, 12 or 24 volt.
As 12V with the 35A controller, you can never utilize more than about 50% of your installed PV, but it will output 500W for as long as your bigger array will produce 500W - probably about 4 hours per day. You are well under the over-paneling limits of 40A max PV Isc and 150Voc:
If you want to fully utilize your array, you will need additional MPPT.
