dirt diggler
- Apr 8, 2020
- 105
Ok straight into the begging for answers
I am in the process of converting an ambulance to RV, it already has a full 12V managment system with smart charge alt, battery isolator and more electrical gadgets than i can shake a stick at, these will be pared down to suit my needs as i progress, i have shore power hookup and an onboard battery charger but no inverter, i may or may not fit an inverter i don't really need one although the wiring and controls are there for it (removed before i purchased the vehicle), i have a generator if needed and my mains sockets are fed from the shore hookup or the missing inverter, i should state here i'm a mechanic of 30+ years so i know my way around a 12V system just fine BUT i allso recognise that a little knowledge is a dangerous thing hense joining here
I have spent a while searching the archives but couldn't find an exact answer i'm confident in using
My system as it stands is 4 X 100W renogy pannels (specs below), now due to roof size issues i can fit either 4 or 6 pannels to the roof (2 or 3 either side running length ways), i realise than due to living in the higher N latitude (between 51 and 57 deg) i would gain power by tilting my pannels but due to the width restriction on my roof if i tilted both sides to over 50deg the sothern pannels (or front most pannels) would shade the northenmost (rear) set (hope that makes sense ? i'll be parking facing east for sake of argument with the right side of the RV facing south), my thoughts are to tilt the northermost (rear) set leaving the southern set flat, would this cause the same issues as shading 2 of the pannels ? my thinking is there would be an unequal amount of power from the 2 sets?
So onto the actuall question, the age old dilema, (dun dun daaaaa), serial or parallel (yes i bet you knew that was coming) or do i connect 2s 2p ? or 3s 2p if i can fit another 2 X 100W in the system ?
I don't as yet have a controller (that's the next question for a recomentdation), my battery bank at the moment is 4X100Ah AGM batterys, i could fit more but they would have to be fitted on the other side of the van, not a big issue and one that will be decided after i use the RV and finalise my loads.
I should add that just to confuse matters (for me) both sets will be hinged inwards so i can park either facing east or west and tilt the rearmost set to gain extra power (ignor this part for the sake of this post i just like to add it all for compleatness and to save on your time), I think i've coverd it all but ask away as i'm sure there's more info that would help in answering these question.
Thanks for taking the time to read my meandering drivvel
PANNEL SPECS
PANNEL SPECS
Maximum Power: 100W | Maximum System Voltage: 600V DC (UL) |
Optimum Operating Voltage (Vmp): 18.9V | Open-Circuit Voltage (Voc): 22.5V |
Optimum Operating Current (Imp): 5.29A | Short-Circuit Current (Isc): 5.75A |
