caz
Hi guys, I have just recently purchased a ute with a dc-dc system. Unfortunately the owner could not give me much information on the set up. I am trying to work out alternative ways to charge my batteries while not driving or only driving short distances as I do not have solar yet. I'm running two lithium batteries in parallel (260ah) through a renogy 30ah dc-dc which I am pretty certain has a built in regulator and input for solar. Does this mean that if I attach a solar panel it should be one without its own regulator? Unless I attach it directly to the batteries then it should have its own regulator? I do also have two batteries under my bonnet, my starter battery and a deep cycle. The deep cycle apparently powers all the extra lights etc around the ute and switch in the cab. I also have an Anderson plug coming off the back of the ute, how can I tell if I can attach a solar panel via Anderson plug to that? If I buy a 240v battery charger what amperage would I need? And any recommendations on brand etc. I have a few more questions regarding solar and my set up but would be great to get some comments on these initial queries cheers and thanks
