Anyone have experience with these?
Recipe for a roof panel fire?No, you shouldn't walk on any panel!
Those flexible ones will surely cause micro-cracks on the cells.
I've had the opportunity to work with raw sunpower cells. I can tell you that while they are somewhat flexible, they do crack too. Any pressure or force on these will make the solder points stress points on the cell and cause them to crack.
Not recommended.
No more your own safetyRecipe for a roof panel fire?
Macht nicht mit der gerfinger poken du focken dese springwerken bleksem poesNo more your own safety
So you not cut off your feed or finger by vallen, thanks to the breaking glas
At $6+ dollars a watt you better be able to f___ on them like the above poster mentioned.These seem great. Much like on a boat, semi disposable.
Semi-Rigid Walk On Marine Solar Panels | Custom Marine Products
Discover high-quality semi-rigid walk-on marine solar panels at Custom Marine Products. Our collection offers durable and efficient solar panels designed for the marine environment, perfect for boats and yachts. Enhance your vessel's energy with our reliable and easy-to-install solar solutions.custommarineproducts.store
That's the ideaAt $6+ dollars a watt you better be able to f___ on them like the above poster mentioned.
