NewGuyNoob
- Jul 30, 2021
- 86
Yeah, a lot of these things aren't properly documented/not documented at all, and Tech support is not much help. ?
I think your idea of the GitHub is the way to go to share all these Modbus examples. I can probably get around to it after next week and share it.
@NewGuyNoob Im using another system to get/store/visualize the schneider Modbus data but I want to move to homeassistant. I will share when done. Right now, I'm only using enough information for basic status and to change XW Inverter settings on different triggers.
In my system I have two XWPro. I have my system setup for grid export and leave the battery at 60%-70% SOC. I have a command to change those parameters on both XW at the same time to charge to 100% SOC. I use it if there is a storm warning, or the power company announces possible load shed due to not enough generation. By having the system at 50%-70% for many days the BMS SOC is off, so I have a trigger weekly to disable grid export and charge the battery bank to 56V so that the BMS recalibrate the SOC.
I have home assistant as well. Currently I have large battery modules that I will set up, it seems I will use the PACE BMS 16s200A for these 17kw modules. I expect to setup communication with my Schneider system via CAN and pull data for home assistant, then push this to HA. Or I will continue doing as we are doing now.
I have one XW Pro, and plan to purchase another soon. One has met my requirements so far, but I would like two to help offload some of the AC loads that I use, MiG TiG and plasma cutting with Shop Air, can draw a lot of power. So load managment is a must. I am fully off-grid and will remain that way for the foreseeable future.
I do have a problem validating the following code, via Developer tools - Validating the YAML, any thoughts?
YAML:
##########SEMB_BMS 0 Modbus SlaveAddress (Port 502): 230#########
modbus:
- name: EG4 Internal BMS
type: tcp
host: 192.168.1.179
port: 502
delay: 2
timeout: 15
sensors:
- name: "EG4 Internal BMS - Battery SOC"
data_type: uint16
unit_of_measurement: V
scale: 1
slave: 230
address: 40081
scan_interval: 15
- name: "EG4 Internal BMS - Battery Current"
data_type: uint16
unit_of_measurement: A
scale: 0.01
slave: 230
address: 40114
scan_interval: 1
##########XW Pro 6848 Modbus SlaveAddress (Port 503): 171#########
- name: conext gateway
type: tcp
host: 192.168.1.179
port: 503
delay: 2
timeout: 15
sensors:
- name: "0 - XW 4868 Inverter Enabled"
data_type: uint16
input_type: input
slave: 10
address: 71
scan_interval: 1
- name: "0 - XW 4868 Active Faults Flag"
data_type: uint16
input_type: input
slave: 10
address: 75
scan_interval: 1
Code:
integration = await async_get_integration(self.hass, domain)
File "/usr/src/homeassistant/homeassistant/loader.py", line 879, in async_get_integration
raise int_or_exc
ValueError: Invalid domain automation.reload*#data_type
