Sorry for not getting back to this thread for a while, I have been busy. I did opt for the moment to exclude the batteries (will add next year) and got a quote from signature solar for the 18KPV and 15-16K of PV (I could go more but I never want to push the inverter to its max and risk reducing its life span). They quoted 34 455 watt panels with 34 Tigo rapid shut down modules which brings me to a few questions.
1) Do I need a module on each panel??? Can't I just have 1 for each string? The last thing I want is 34 electronic boxes baking in the Florida sun and rain.
2) Do the rapid shutdowns turn off the panels when the grid goes down or only when an emergency switch is engaged? I want some power when the grid goes down which is partially why I opted for the 18KPV because it has its own grid disconnect.
3) Do I need the Tigo Cloud connect? I do not want any of the system online. Call me paranoid but if there is a planned grid attack it is not out of the realm of possibility that they could push a firmware update that could crash the PV system just before crashing our grid.
4) Down the road how would I add more PV if I wanted? I don't want to add more directly to the 18KPV because it is already to its max and I would not be able to add enough extra PV to justify a 2nd 18KPV.
Here is the revised parts list they quoted me.
Here is a quote for the grid-tied EG4 18kPV system. Let me know if there are any changes or adjustments
that you would like made to the quote.
Let me know if you have any questions.
Unit Price Qty Extended
EG4 18KPV Hybrid Inverter | All-In-One Solar Inverter |
18000W PV Input | 12000W Output | 48V 120/240V Split
Phase | EG4-18KPV-12LV
1602002
5,599.00 x 1 5,599.00
Solarever 455W Split-Cell Mono PERC Solar Panel ( Silver )
1545006
254.97
-13.07
241.90
x 3 764.91 -39.21 725.70
Solarever 14.11kW Pallet - 455W Split-Cell Mono PERC
Solar Panel ( Silver ) | Full Pallet ( 31 ) - 14.11kW Total
1545006-31
7,499.00 x 1 7,499.00
50ft 10 AWG Copper PV Wire | Black and Red
1534011
60.80 x 2 121.60
100ft 10 AWG Copper PV Wire | Black and Red
1534025
104.50 x 2 209.00
Stäubli MC4 Male and Female Connector
1577005
3.04 x 6 18.24
Wire Ratchet and Crimp Tool | MC4TM-Style
1577004
20.89 x 1 20.89
Stäubli Open End Spanner Set
1577003
9.49 x 1 9.49
End Clamp for Mini Rail | 35mm Silver 1.50 x 16 24.00
1557003
Mid Clamp for Mini Rail | Fits All Silver
1557010
1.50 x 60 90.00
6in Asphalt Mini Rail With Flashing Roof Mount for Panel |
Silver
1557012
10.50 x 76 798.00
PV 2 Wire Management Clip | 50 Pack
1503008
11.88 x 2 23.76
Tigo TS4-A-S Module Level Rapid Shutdown | 15A,
700W,1500V UL/1000V IEC | MC4, 1.2M Cable
1594012
37.32 x 34 1,268.88
Tigo Cloud Connect Advanced (CCA) Outdoor Kit | Tigo
TAP, Din Rail PS, Outdoor Enclosure
1594002
310.47 x 1 310.47
Subtotal $ 16,757.23
Discount -39.21
Shipping Select at Checkout
Total $ 16,718.03
