I have a 498Ah 8s2p setup where the two packs were recently installed in parallel. I top balanced both packs and charged both individually to 28.00v before connecting them together. As expected the voltages are identical as measured by my dual JBD BMS's and current flow between them at idle is 0. But under draw, or under charging, one of the packs draws or charges with slightly more amps, for instance at 18a total, 8.75a comes from pack A and 9.25a comes from pack B. Its not a huge difference but is throwing off my BMS SOC calcs somewhat and Im wondering if there will be other negative effects.
Using a clamp meter, I see that the amp difference only appears on the negative side, not on the positive cables where the amp readings are identical.
Pack B currently has longer cables to the distribution blocks where the two are tied together. The round trip is about 50cm/19.6" greater for Pack B. The thing is, Pack B has the higher measured amp draw. Due to the higher resistance of a slightly longer cable, I would expect the amps to be lower on that pack, not higher? Unless I'm missing something.
I'm planning to make the cable lengths identical to see if it helps. But I'm wondering about the science and why I might see different amp draw for Pack B which has a longer round-trip cable length. If not the cable length, what other factors could cause the current disparity?
