sd_dracula
- Apr 12, 2021
- 24
I have a pack of 32 eve cells 305ah in a 2p16s configuration and I'll be splitting them into 2 x 16s packs with their own box/bms.
Wondering which of these two methods is best for connecting them together.
(I do have a 200a fused disconnect before the inverter connection)
1. Use a solid busbar between the -/+ of the packs and then wire pack 1 positive/pack 2 negative with 2x35mm2 to inverter?
2. Wire each pack with 35mm2 cables to inverter and not join the packs together at all?
