I have an ampinvt 6kw split phase inverter in my RV. I don't need 240V. I figured it was the easiest way to power the A/C, stove, oven, disposal, and dishwasher without juggling 2 inverters.
I want to retire the 24V power supply that I use to charge the batteries, and the transfer switch. But the wiring has me scratching my head.The inverter has just two hot legs as input and Ampinvt replied that I should connect just the 2 hot legs of a 240V supply, and not the ground or neutral.
However, before I got that information from them, I had connected the mains ground and white to the output ground and neutral and a single 120V hot to both HOT1 and HOT2 on the input.
It seemed to work fine. It ran current to the battery, and when I altered the voltage that triggers charging to be below the battery voltage it stopped charging and the battery was providing the normal current for the DC loads. The microwave and oven clocks were on, but that was the only AC load.
I am wondering how this inverter/charger works?
I assumed that these all had transfer switches, but maybe it does not. But if not, does it take in the 240V and produce the split phase output? If so, how does it deal with the fact that there was 0V across the input?
If it does have a transfer switch, then how would it produce the 2x 120V legs a 240V input?
