Roof Prep
You probably noticed in the earlier photos that the roof is white. It's
Henry's tropi-cool white silicone roof coating. The roof has been in the sun for a while in this photo and is obviously quite cool. I've been up there a lot, and it's always cool to the touch. The downside is it is very slippery when wet. In typical local style, it also took
forever to get done, which helped push the deployment into 2020.
I wanted to put a new coating on before the panels went up as I didn't want to have to take them down in 10 years just to re-coat the roof (has a
limited lifetime warranty so hopefully will last 30 years). I always thought it would be a good combination with bifacial panels, but those need to be elevated a bit off the roof and in my hurricane wind high velocity projectile zone that just wasn't in the cards.
I picked this coating from the CCRC data looking for a "cool roof". Henry 988 has the same
CCRC stats as 887 (I think one is the homeowner version and the other a contractor):
AFAIK, this is the best there is for a DIYer to keep a roof cool, and that'll reduce the AC bill so you'd consume less power.
When I put it on my roof I even got a state rebate for an energy credit!
As you probably also noticed in the earlier photos, having a cool roof did not allow me to skip the elevated roof conduit nor the lower gauge because the NEC rules only use highest ambient temperature, not roof temperature. It's amusing that the elevated conduit temperature is hotter than the roof temperature.
