Howdy.
I have the following gear, and I'm looking to tie it together:
EG4 6000XP with 20 370W panels and 24kWh of LiFePO4 in two parallel groups of 12kWh/ea
Two Delta Pro connected via Infinity cables to a Smart Home Panel (First Gen)
The EG4 6000XP is basically just sitting there not really connected to anything yet
The Smart Home Panel was wired in by an electrician, and feeds about half of the house
The no-brainer option is connect the 48V batteries to the XT60i connectors. But 2*(48V*15A)=1440W is severely limiting the input power. If I've got a bunch of window AC units on all day, this setup will not keep up.
I could use DC-DC boost converters or rewire the SHP to connect it to the 6000XP, but that involves conversions (either DC to AC to DC again, or DC 48V to a DC higher voltage), which are inefficient.
Any other magic tricks anyone has been successful with?
Thanks,
Chris
Thanks,
Chris
