Goboatingnow
- Jul 3, 2022
- 1,325
the Tristar MPPT in unusual in that if the battery voltage falls below a certain number it will not restart until the voltage has risen to a higher number clearly this can cause a " lock-out " issue if no other source of re charge is necessary ( must MPPT units only have panel lock outs )well, they do, but what i mean exactly is to protect this equipment from downtime. from what I understand, the TS-MPPT-60 will not charge power on just off of voltage from solar array input, so if my batteries get completely depleted, the entire system shuts down and the batteries will need to be replaced when they could just have been recharged. this is for communications equipment so we are working in extremely remote locations with 99% required uptime.
This is always a problem with having a single source of charging , the best way around is as you say a load disconnect before the MPPT brownout voltage is reached , this solution is simple enough you need a Vicron smart battery monitor ( assuming no big inrush loads are present , like big inverters) or a simple low voltage monitor board ( aliexpress, amazon , ebay ) driving a power relay , as this can cope with the big inrush currents
