rmharrington
EG4-6500 Slave Not Pulling From Solar
Hi all. It's been a long struggle but I finally have my Eg4-6500 system up and running in split phase. The A/C inputs from batteries and from grid work exactly as required. The solar also outputs from the panels to the inverters as desired.
So, here's the problem.
I have two strings of nine 340 watt panels, one pushing to a respective inverter. The main inverter pulls from solar, batteries, or grid as required for any specific time-frame. However, the slave inverter will not pull power from the solar. It runs fine off the batteries and/or grid. It just refuses to acknowledge any incoming solar resources.
I have IMO DC disconnects at the panels, one for each string. I have IMO DC disconnects at the inverters, one for each unit. On a good day, the main inverter will pull 2.5 to 3 KWs of power. The average amps produced by either string hands between 3 to 10.
Concerning the second string, and the slave inverte. I have tested the volts and amps at the panels. I also tested the feed going into and coming out of the IMO DC disconnect that feeds said slave. The supplied KWs are in line with what is available to the main inverters. Both inverters are set identical with the exception of option #5. Wherein the main is set as EG4, and the slave is set as USE.
Can anyone point me in the direction of a solution to this problem? I need that extra power before I can upgrade my subpanel options.
Thanks
Thanks
