Rob_in
- Sep 15, 2022
- 2
Planning a solar install here:
- Rooftop panels in 3 strings of 3 series to a single MPPT charger.
- Charger, inverter, etc. will be in a cabinet approx 80ft/25m from the panels.
- The 80ft/25m wiring route from panels to charger is into & through the house, 16ft/5m or so underground to the garage then 10ft/3m or so inside the garage to the MPPT charger.
There are 2 options for combiner box, etc:
1. I read in various manufacturer instructions that say there should be an SPD near the panels and another near the MPPT charger if there is more than 33ft/10m between these. So on this recommendation the combiner box should be placed directly inside the house with breakers & SPD, with a single, large gauge cable to the MPPT charger and have a second SPD there.
2. However... we already have a large electrical box around 23ft/7m inside the house on the route the wiring would follow. This would be an ideal location to run each string to and have a combiner box with breakers and a single SPD. This option would be far more convenient for installation and access to the combiner breakers & SPD.
I am thinking that while option 2 goes against SPD recommendations surely with such a relatively short wiring run either side of a single SPD it would still offer the necessary protection.
Any thoughts/recommendations on this?
