NordicNerd
Ok so I wish Giandel had better documentation - discussed in other topics. I am looking for advice on the best way to approach my build. Options are:
1. Ditch Giandel and go Victron Multiplus II (I'll need to figure that grounding out)
2. Figure out how to to the sketch below with a GFCI (offered in a different thread) - not sure how to implement this with the 3000w hard wiring.
3. Remove the ground neutral bond from the panel and wire like a load center not a main.
Problem with current wiring - overloaded / fault with inverter when switched on (inverter buzzes - at least it didn't blow up). I shut it down and disconnected the battery
My plan was to upgrade the system later after my off grid cabin build and use this system for a small bunkie. When the cabin is built I would use this system as a temporary measure (was looking at the EG4 6000 xp 48 volt system) - that might be 2-3 years away yet.
Thanks to all for any advice / experience you might offer.
