iampob
Hi all,
I added the Emporia Vue 3 to 16 circuits on our main panel, about 3 weeks ago, I'm trying to understand if we can use 1 x 6000xp for all the house circuits, apart from the hot tub and dryer, which would be running straight from the grid, that's the very loose plan at the moment anyway...
I've just downloaded a 3 week report from Emporia, and it shows peak usage for every 15 minutes.
Just wanted to make sure I'm understanding the report correctly, and what the options might be.
The Mains Phase L1 - Watts + Mains Phase L2 - Watts columns are the CTs on the 2 grid 120v coming into the panel,
the Minus Dryer or Hot Tub - Amps column is the 2 x 120v totals, minus 2 hot tub legs and minus the 2 dryer legs, then converted to amps.
Hope that's making sense,
If I'm understanding this correctly, one 6000xp should never get near the 25 amp (3000w) per MPPT limit if we run the dryer and hot tub straight from the grid, and everything else from the inverter?
then I guess there's a second question, is there a way to get the majority of circuits into a new panel so they can run from the inverter, and then downsize the existing 40 breaker panel that will keep the dryer and hot tub circuits on the grid?
or is there a way to move just the dryer and hot tub to a new panel, and relocate the grid to that, without needing to get the power company and temporary disconnect requested?
or, what other approaches could be done?
thanks for reading through that jumble of words!
