I want to add 14K of panels and inverter to a 50'x60' metal building that is 150' from the utility meter. Original owners started with an apartment in the building so it has a small 125 amp CB panel and under ground power line. House was added ten years later, closer to the street, and the under ground line changed to a meter on the house. The meter panel connects to an adjacent, external, 200 amp CB disconnect (picture) and to two 200 amp internal CB panels. The external panel connects to the line going to the metal building.
1. Local utility requires the external disconnect panel be lockable and have an external handle, so I need to change. Looking online, I see fused and not fused, two and three pole, with prices rapidly increasing. Any recommendations for the replacement?
2. Both Sol-Ark and EG4 diagrams show CT clamps at the meter and I want them near the inverter at the building's CB panel. Do they just confirm grid availability or do they measure demand and control the inverter? Hope I don't have to run wire underground back to the panel area.
Better solution to #1 is to change the external meter connection from meter to the internal CB panels, and back up more of the house. Primary goal is lower grid usage with monthly net metering.
