I am trying to understand safety on this setup.
1. Can I use a common ground?
2. will the On/Off Switch work to safely disconnect the battery.
3. If solar and Car are both connected using common ground will that cause me any issues? - Common ground was not encouraged or discouraged in the manual so it is unclear.
*Note - Fuses and breakers are all appropriate considering loads and manuals.
** Note - Wire awg is all approprite considering loads and manuals.
