its 24 batteries 2v RES 5 SopZs 860 lead acid equal to 30kwh capacityNo idea.
Don't know what type of battery, capacity, and I don't see that the actual current is included on the "battery voltage and battery current" charts.
Isn't the load of the home enough to know if there isn't a graph for the current?And the current?
I think the angle of the slope depends on what time frame is on the horizontal axis. I agree that if you are using more energy than your PV can provide, then you need more PV. The two important variables to look at are production and consumption. I like to view those numbers in Watthours or kWhours to eliminate voltage differences. The batteries are only an intermediary. They allow you to store production when the sun is shining and allow you to shift consumption to a time period when there is no production. There will be some loss in doing that.Did you note how the decline from v boost to v float isn't as dramatic as in my case?
I'm just wondering if the batteries need to be replaced or if I simply need more PV panels.
I should hope you can put it together from your own chart. Only a few days did you cover your loads with solar.
I will undoubtedly install PV panels; I simply need to know if the batteries are nearing the end of their useful lifeI don't understand how you can think this is a battery issue in any way.
You literally just posted a table full of data showing you rarely produce enough PV to offset your consumption.
Of all the data provided, you only covered 78.4% of your consumption via PV.
It's clear you're compensating with another AC source (grid? Generator?).
Are you getting the batteries fully charged?
What logic determines when you draw from AC source?
Since the batteries were installed three years ago, I'm wondering if their life is coming to an end, and I'm not sure how to configure this. That's why I'm showing the battery voltage so you can tell me if the batteries are discharging quickly ( huge slope)
