littleharbor2
That statement is referring to a wiring scheme that doesn't use bus bars. Your drawing shows loads and charging separated and not at opposite DIAGONAL corners.In the same vain , im not saying good or bad , but just read this .................
"The battery cables should be of the same length and same size and as straight as possible. Always connect loads and charging sources to positive and negative terminals at opposite ends of the battery bank, otherwise the first battery will do all the work and the bank will become unbalanced and fail quickly.
