Battery 12v x 8 : 24v
Koincave
UK
I was running 4 x12v batteries at 24v all was fine
I have now expanded to 8 x 12v batteries at 24v
and wired like image obtained from the web , all is working fine but im not comfortable with it , is there a better way ?
What battery type? Only thing I would do is maybe add a midpoint voltage meter.
Read the first 4 posts of this thread to understand the issues. There are better ways to wire your batteries (not terrible, i've seen lot worse!)
Thankyou mr Sandals appreciate time taken to reply
I have had a quick look and its gonna take me a long time to
fully understand. I am currently spoonfeeding myself with easy to read
images from the web , understading fully is good but its also very time
consuming a brain numbing
anybody any thoughts on rewiring like this attached image
The goal is to load / charge all batteries as equally as possible ,
The trouble with that diagram is the load isn't spread evenly at all ... the two batteries at the top are going to have to do more than their fair share of the work and so degrade faster....
each pair of batteries down will do less and less
This would be a lot better (simple fix):
Drawing/charging the bank diagonally spreads the work across all more batteries evenly
The original parallel-series is likely marginally better with 24V and lead acid and no balancer. It is good to monitor the voltage though between the two endpoints and midpoint (the two 12V readings). The logic is the charger is only controlling the 24V nominal voltage, so you only have one indeterminant point within your control.
When you go series-parallel then the four midpoints are all indeterminant.
The difference is only marginal though since you have 24 indeterminant points within the 8 batteries themselves.
Thankyou , the smart guage link a lot easier for me to understand , although i need to put some thought into it for 24v once i have decided which method i prefer
it was worth reading just for this comment , which have been wondering :)
"And finally, finally, we keep getting asked where the chargers should be connected to. We didn't address this question because it seemed so blatantly obvious where they should be connected that it never occurred to us that anyone might be unsure. The chargers should always be connected to the same points as the loads. Without exception."
The blue lines , what do they represent ? , might seem obvious to you , but just confusing me :)
Someone on here sent me that link when I was first starting out , always found it very helpful
Oh ! I think they're just annotations, like arrows for that label
Definitely not cables , ignore them
OK cool , i thought so but just wanted it confirmed
Ok to move to that pack is quick and easy, easy install of 3 short cables
Interesting that the load/Charge + has moved to bottom right post
I shall experiment with that first, i think my preferred method is "method 3"
easy to understand and easy to add new batteries in due course , but that will
take more work and cable to change
Yes it's a good bit of cabling to get method 3 sorted but ones it's done it's done
Try cut all cables the same length - again aiming to equally drain the batteries
Here is method 3 for 24v:
Just going to rewire just now and spotted a difference between images
although they look similiar
the image i put up, you draw + from top right post
the image mr sandals put up you draw + from bottom right post
any thoughts anyone ?
Ok just checked the voltages of each battery , the left bank were all lower
so i would say that means the original way i wired , very first image , in my very first
post in this thread was , "operable but poor " :)
I have just rewired and using bottom right post for charge / draw , lets see how it goes
i shall report back in due course
Brilliant , if they are unbalanced it might pay to disconnect all batteries, individually charge each one for 12/24hrs on a little 12v charger , and then after that reconnect
This will make sure all batteries are at the same level - completely full
The reason we draw on the system diagonally is we are trying to load each battery equally ,
Sooooo what do you guys think of this method .....
see attached file.
Key difference is the charge controller volts in are at
the opposite poles from the load draw
I cant say if its good or bad , just looking for opinions
in my head it makes sense ....
In the same vain , im not saying good or bad , but just read this .................
"The battery cables should be of the same length and same size and as straight as possible. Always connect loads and charging sources to positive and negative terminals at opposite ends of the battery bank, otherwise the first battery will do all the work and the bank will become unbalanced and fail quickly.
