Hi everyone on forum,
Looking for battery option which would secure following, while i want to be sure i am not compromising battery logetivity in any way(so if i would do 4k cycles at have remaining 80% capacity or more would be fine).
Here are conditions/scenerio:
Atm i am working on mounting 320W solar panels on the roof small caravan with 100/30A Victron MPPT. Because i intend to stay fully off-grid during winter time in Scotland i can see i will need extend PV array -> i think i will be able to accomodate additional 200W-400W on mounts when caravan is stationary and will just mounted at place i stay for long time.
Lets say i would be coming back to caravan at 6pm evening temp. is about 5C inside.
Now i would use 2kw inverter for 3 minutes boil water coffe and simultaniously washing machine on other inverter take 250w and charging batteries 80watts for my dewalt tools. Also I would use computer on DC 80W, lights 20W, let my head lamp charge and phone - 20W. Fridge would take up to 60W.
Big Inverter(planning to have 1 small 400W and 2kw) would go for short time like 5-10 min max.
Its not realistic typical day scenario, but it can get close to this smth like - 2600W discharge rate 216 amp draw. To me sounds very unhealthy for battery life(just in terms of discharge rate).
NOTE: i spoke to diff. sale representatives one did comment that doing discharge over 0.5C isnt good for battery life, other said its not problem, refering going that their batteries can handle 3200W 200ah(https://roamerbatteries.com/shop/p/12v200ah) - though different batteries, here lies confussion for me AND If someone can give opinion here).
To sort and be save here better to go for 2*100Ah batteries which are in total higher rated than single 1*200Ah, almost double?
There is low temp in play, so i wonder how discharge change once we getting close to 0C? say what difference between 0-10 and 10-25 in operation towards longetivity?
They have range for batteries you can go charge -30C so eventually i can go for these yet, might be overkill.
Dod should not be the problem, i would just set limit to myself that i won't cross 50% unless it is really neccesery. I found i would use on average 55-80Ah per day in worst case scenario.
Kettle 2Kw 6 min - 17 amph
Toaster 1Kw 5 min - 7 amph
Laptop 65W 3 hours - 17amph
Fridge 150w in 12h - 12.5 amph
phone charge 15w 3 hours - 4amph
Head lamp 4w 3 hours - 3amph
Lights 20w 5 hours - 8amph
+- 70 amps
I want to know boundaries, if all iam suggesting is just stupid use, which will cause big problem to battery, i would need to change usage and would use rather GAS or using lower rated appliances or just avoid big inverter all together, but i am more about to expanding system rather than restrict it, thats why i am asking this way.
Second thing is charging, if i would get 600W solar panels and manage to push more than 50A to the battery at some point during the day, how this can effect battery life(not temporarily - its more about really long term), again lets say scenario when temp are low 5C?
I am taking into account that i will be managing heat by insulation, yet just would like to know where is limit for battery to be charged with high current?
There are also batteries using heater, yet what is draw for heater and how it would be in winter, how much heater takes from PV yield during the day -> so it makes it sense to use or not( i guess depends on temp. need to regulate and weather conditions - very hard to say, but practically does someone using this or have good idea if this can make sense or not?)
NOTE here: those batteries which can be charge up -30C dont have any heating as they claim, so efficiency here can be better in this regards.
There batteries where 300ah capacity has only 26 Kg, heater inc. etc.
This is a bit suspicious when i look at others e.g 200ah renogy is 27kg. Price for this is very very low, but i suppose there might be some catch.
Appriciate any comments advices, its first battery purchase with practically 0 exp., so you might find a lot of irrelevant what i am asking but better say than be sorry later.
Petr
+- 70 amps
Lithium Leisure Battery - Fogstar Drift 12v 300AhDefault Title
300Ah Fogstar Drift Lithium Leisure Battery | Grade A LiFePO4 cells, High Discharge BMS, Bluetooth, Heating | Lowest Prices in the UK. 10 Year Warranty.
www.fogstar.co.uk
Petr
