I have an 8kw system with enphase microinverters installed about 2016. It is under a 20 year PPA agreement so I really cant modify the system. The system ties into my main panel via a 2 pole 40 amp breaker. The main problem Im trying to solve is I want to add a battery backup to the system that will allow the panels to continue generating power and charging the batteries when the grid is down. Right now they use anti-islanding and shut down during grid failures.
What kind of inverter would i need to be able to supply 120vx2 power to the micro inverters to trick them into producing power?
