Hello people,
I current have a Renogy 12v 50Ah lithium battery that I dont think is working correctly.
The battery is kept in the back of my van to run 12v accessories (water pump and led lights) and I charge the battery in my home using mains chargers (either Noco Genius 5 or an Optimate lithium 2amp charger).
The voltage is monitored using a small accessory that is attached directly to the battery terminals and appears to match multimeter readings.
Issue 1
- Battery only seems to get to arround 13.66 volts before charging stops. My understanding is maybe a cell is reaching a high voltage and the BMS is cutting the charging path? If the cells are inbalanced, how can this be fixed with a sealed battery? Is this a warranty issue on the battery? If the voltage drops to 13.4 after charging should I be concerned it stopped charging at 13.66v?
Issue 2
- The battery voltage under zero load can suddenly and randomly drop from say 13.3v to 12.8v? It usually jumps back at some point, as shown below, but again what might cause something like this?
Any help would be appreciated. Renogy suppport is terrible and they ask basic questions like is my charger set to Lithium mode.
Issue 1
Issue 2
