Hello all. Posting this in hopes to see if anyone else had the same failure or experience. Back in 2020 I purchased four BB10012 batteries, connected them in parallel using 4/0 cable, decent lugs, torqued terminal bolts to 10 ft/lbs in accordance with battleborn's manual, and installed them securely in my RV. System consisted of the four battleborn battery bank, BMV712 shunt, Victron Multiplus 12/300/12 inverter, two victron smart charge controllers 100/30 250/100, (all these items purchased from battleborn) and 10 200 watt solar panels on the roof. From then to now we had maybe five or six RV trips, two of those trips were longer trips (over 3000 miles). RV is stored in a shaded spot, unplugged from shore power, and the charged batteries switch is turned off to disconnect batteries from system to prevent parasitic load discharge. This last trip had to be cut short because I started getting the low voltage and DC current ripple warnings via the victron app and the system will shut down. Called Battleborne tech support and they adviced to disconnect every cable that was attached to or touched the victron inverter, wait one hour, then reconnect everything and the problem should be fixed, which I did per their instructions but didn't fix the problem. It was weird because I would check with my multimeter and I would sometimes read voltage, and sometimes would not read anything. Long story short, once I got home from the road trip I disassembled the battery bank and turns out ALL the positive terminals in each battery were lose inside the actual battery case. At first this was only detected in two of the four batteries but turns out all four batteries had lose positive battery terminals inside the actual battery case. So I sent the fisrt two (discovered) batteries in for warranty check, then told them about the other two batteries to what they responded to wait until the first two batteries were diagnosed before sending them im. It took them almost two weeks to inform me the finding was EXCESSIVE CELL INBALANCE DUE TO LOOSE POSITIVE TERMINALS CAUSED BY HEAT BUILD UP ON TERMINALS and that the batteries were beyond repair. When discovered the first two battery voltages were 13.35 (batt1) and 13.31 (batt4), and the other two batteries were 13.44 (batt2) and 13.34 (batt3). How is this possible? Sounts to me like a design flaw. What's the BMS for then? Everything was torqued to specs and checked periodically. The highest item we ran on this system was the roof AC and not all the time. Is this a "get you a lawyer and fight" situation? Even worse, ME thinking they were going to grant my warranty I purchased five other SAME MODEL batteries from them to upgrade my system and now this. Very upsetting. Anyone else had the same failure or experience? Videos I recorded are too large for attaching on here and link is provided below. I also attached some pics of the type of cables and lugs used. Thank you
Serial numbers for the four failed batteries were 56666, 56414, 56538, 56541
Battleborn Batteries Issue - Google Drive
drive.google.com
