Hi.
I'm planning on fixing a system on the roof on my canopy (pick-up) and did a lot of research before buying.
I ended up with this;
Victron smart solar 100/20
24v 250w solar panel.
12v 150Ah lifepo4 battery.
The thing is, I didn't plan to bother how the BMS was configurated until I used a lifepo4 wall charger and realized that it was charging with less volts then desired (13.6v) and that led to a snow ball effect.
I ended up buying a better wall changer more suitable for lifepo4 (victron blue smart ip65 12/25) that delivers 14.2v.
I used the xiaoxiang app but it doesn't show much info and I ended up downloading the overkill app.
I read the doc. on this forum regarding voltage/charging/BMS and realized that my BMS doesn't agree on those values.
I have attached print screens from the app above.
I haven't made any changes except the value "total cycle capacity" which was set at 125 000. I set it at 150 000.
My goal is to use 85-90% capacity of the battery but all these numbers seems to be all over the place.
Or should I leave all these values stock for warranty reasons?
Help!
Help!
