littleharbor2
I'm basically bench testing a 12 volt 305 ah. LiFePo4 battery build I'm doing for a friend for his RV. I have the battery connected to an inverter for load and a Xantrex C-60 for charging, It appears to start out working fine but then CC goes open circuit soon after connecting. This open circuit voltage causes the BMS to cut off charging due to an over voltage situation. Could there be an issue with the C-60?
