nthnmchrlly
- Jul 25, 2020
- 3
Hi, sorry if this is a noob question but dont really have anyone to ask so yeah, I recently built my first Lifepo4 32650 battery pack on a 2s4p configuration coupled with a 10A BMS. When charging at set 7.2v but it only takes 1A off my CV power supply even when I set the current limit higher than that. Upon checking the specs of the BMS it states that the charging voltage is 7.2v-8.4v, so I then decided to increase the charging voltage to 7.6v and now its charging higher amps so I set my current limit to 4A. Is it safe to charge like this? Cause going back to charging at 7.2v at 1A for my 20Ah pack would take a long time.
BMS is:
Model: HX-2S-JH20
Module size: 46.7*23*3.15mm
Upper limit working current: 10A
Upper limit instantaneous current: 20A
Over charge voltage range: 3.65±0.05V
Over discharge voltage range: 2.0-2.5V±0.05V
Static current: <10uA
Charge voltage: 7.2V-8.4V
Short circuit protection: yes. Delay self recovery
![BMS-2S-10A-Lifepo4-Battery-Protection-Board-with-Balance-18650-BMS-PCM-for-Lifepo4-Battery-Cell.jpg BMS-2S-10A-Lifepo4-Battery-Protection-Board-with-Balance-18650-BMS-PCM-for-Lifepo4-Battery-Cell.jpg](https://diysolarforum.com/data/attachments/18/18452-3faac49428ed583dcfa932f7c1fd1d21.jpg)
![IMG_20200720_185931.jpg IMG_20200720_185931.jpg](https://diysolarforum.com/data/attachments/18/18453-a982bd059e4f1a88c27bde348e3470f6.jpg)
Can anyone kindly enlighten me please.
Thanks.
BMS is:
Model: HX-2S-JH20
Thanks.
