BMS connect to PC via Bluetooth
zzerg85
is it possible to connect my laptop with the daly "BMS monitor" app or other BMS app via the bluetooth connection i already own to my 4s 12v daliy bms?
i successfully connected to my phone app and programed it. but i cant seem to change the "CURRENT WAVE" function which supposed to allow my bms to read lower Amp usage. by deffault i belive it only register usage 2Amp and above. my ceiling fan in the campervan use less. so my state of charge dont reflect this usage and becomes wildly inaccurate. it was showing 50% capacity and it was drained to zero after letting the fan run for a few days with the fridge. by lowering the value from 2 Amp to maybe 1 Amp im hoping to get a more accurate read. and therfore avoid buying a silly expensive victron smart shunt.
any ideas? do i must buy a usb connection as well if i wanna play with PC applications?
