AndreMalta
- Feb 21, 2020
- 2
Hi all
I have a compact car converted to EV using a 48v series wound DC motor with the following basic setup:
Since these are traction batteries, current draw varies wildly. e.g. standing still at 10A in traffic one moment, accelerating for a few seconds at 350A the next, and cruising at 120A. Similarly, voltage can briefly go dangerously low on hard acceleration but goes back to a stable range for long enough to get me back home.
My main concern with BMS systems is with overcurrent and under voltage protection. I wouldn't want to be in a position where the BMS completely shuts off because of a small peak in use, leaving me stranded.
My question is, am I better off fitting a set of active cell balancers and continue monitoring manually? Or are there any BMS that can cope with these peaks by e.g. turning themselves back on and/or have a tolerance of time before it trips?
I have gone through a number of threads on this forum but cannot quite find an answer to my question yet. I have also tried communicating with Daly about their newish 300A-500A variants however the language barrier is not helping me get the answer I am looking for.
Any help would be appreciated.
- 16s Winston Cells LYP300AHA
- Elcon charger outputting 58.4v 25A
- JLD404 connected to a shunt for visually monitoring Volts, Amps, and Ah usage. This also has two internal relays (J1 & J2).
- I am using one of them to disconnect the charger
- The other one sounds a warning when the voltage is getting low
