Hi,
I have a 5kWh Sunsynk inverter with a Sunsynk SSLB1 5.1 kWh battery, and the BMS doesn't seem to work: if I go to the LI BMS menu, , it shows everything at zero. The inverter doesn't seem to know the actual SoC of the battery either (I have 2 LEDs on the battery, so it is between 25% and 50%, but the inverter thought it was only 4%...)
The RJ45 cable is plugged to the left CAN/RS485 port on the battery, and to the CAN port on the inverter.
The battery setup is set to Lithium, CAN, Protocol 0.
I also tested the RJ45 cable and it seems fine, although:
Any idea how I can fix this BMS connection?
Thanks!
- the wire 1 on one side goes to the wire 3 on the other side
- 2 goes to 1
- and 3 goes to 2
- the rest is straight (4 to 4, 5 to 5, etc).
Thanks!
