Interesting. Any results?I had the same issue. China engineer told me to set this value here:
Parameters / Other / Standby Balanced / Starting V
I set: 3350 and I'm waiting for sun to see if it helps
Regards, Petr
I tried this as well (I have a terrible unbalanced 24V/200AH Battery which only charges to 188AH due to hitting overvolt protection on one cell). At least I can see in the monitoring software, that is is actively balancing earlier on now. I will report after some more charge /discharge cycles, if this did any good.Interesting. Any results?
Regards, Petr
I found thé way, how to balance thé battery! Low discharge current 2-5A until one Cell reaches voltage under 3000mV. At this moment BMS Wil do percentage correction (-9% in my case). Balancing starts somewhere around 40%, when diff>20mV, at 25% did percentage correction to 16%. After 3 cycles, everything Is Done!I tried this as well (I have a terrible unbalanced 24V/200AH Battery which only charges to 188AH due to hitting overvolt protection on one cell). At least I can see in the monitoring software, that is is actively balancing earlier on now. I will report after some more charge /discharge cycles, if this did any good.
Matviey, please tell me what cable did you use to connect to the inverter, which socket? Did you change anything in the battery?dddInverter cannot work with DR_App at the same time.
Inverter: Solis RHI-3K-48ES-5G 3kW connected to Battery_1
Solis battery selection: Pylon LV (Pylontech)
I own one of those noname 48V 100Ah AliExpress batteries, the BMS is (probably) a cheap Seplos BMS clone, even the DR-Software seems to be a cheap copy of the seplos monitoring.Never heard of dr software. You might as well disassemble one battery and take some pictures to see if we can identify the BMS.
I hate to say it but that’s what you get for going cheap AliExpress way and not known vendors.
Thanks a lot Matviey! I have the exact same setup and scenario (5 packs of the previous battery, and just got a 6th which is one of the newer types, all from Cerrnss on Aliexpress). I similarly noticed the USB -> RS485 cables were different, and saw the pack's discharge max amps drop to a fail-safe (80A from its usual 320A) when I connected the sixth pack. From what I can gather, the 80A fail-safe max discharge is because the 6th pack isn't communicating right with the others in the pack. I'm guessing if I rig a cable similar to yours between pack 5 and 6, things should work normally again. Well, hopefully.I have two LiFePO4 48V 100Ah 5120Wh from AliExpress connected to Solis RHI-3K-48ES-5G 3kW
First, I bought one battery and six months later I bought second battery.
First battery came with Ver: DR-SAIENSI01 16S100 -V1.0.3T1_G
Second battery came with Ver: DR-SNS09 16S100JC11-V1.2.1T3
First battery had different set of cables in COM RJ45 head than second battery.
Also, first battery works on baud rate: 19200
Where, second battery works on baud rate: 9600
---To fix baud rate (to have both batteries on 9600), I installed .bin config on first battery.
#Battery 1:
Ver: DR-SAIENSI01 16S100 -V1.0.3T1_G (before .bin upgrade)
Ver: DR-DR01 16S100JC03-V2.0.0T1_V (after .bin upgrade)
Product Info: 2.2
Hardware model: T1_V
Product model: DR01
Project code: 16S100JC03
Software version: 2.0.0
Boot version: 1.1
#Battery 2:
Product Info: 2.2
Hardware model: T3
Product model: SNS09
Software version: 1.2.1
Boot version: 2.2
Please find attached .bin upgrade file: DR-DR01 16S100JC03-V2.0.0T1_V.7z
Application which I used to connect was: DR22.07.06
DR22.04.13 – did not work for me (was not able to see any COM ports in my laptop)
Also attached.
---To connect two batteries I made custom cable (normal computer ethernet cable did not work for me):
Laptop with DR_App connected to Battery_1
Battery DIP settings:
Battery_1 DIP 1-6 OFF
Battery_2 DIP 1 ON, DIP 2-6 OFF
In my case, custom RJ45 cable work only in one way. RJ45 Side_A connected to second battery, Side_B connected to first battery.
Battery_1 DIP 1-5: OFF, DIP 6: ON
Battery_2 DIP 1: ON, DIP 2-6: OFF
The result of two batteries in Solis inverter:
If your 1st battery is charged at 100%
your 2nd battery is charged at 50%
Inverter will see it as: 75%
HelloProtocol looks like its the same as my BSLBATT 100ah rack battery.
BMS is PACE, RS-232 doc attached. I created a simple esphome project to extract the data.
This guy made a python script: https://github.com/Tertiush/bmspace
hello.. i have same issues.. did you fix it.. if yes can you help me.. thanksHi. I had this issue with App version DR22.04.13
Try DR22.07.06
hello, i have same issues.. can you help me how the battery back to life?Hello everyone. I just tried to change the firmware and something went wrong. Like friend "nuphor", I tried to upload something else, but it didn't work. Does anyone have any ideas on how to get the battery back to life? The previous firmware DR_SAIENSI07_16S200A_V1.0.3_T1_V.bin, but I can't even upload it back.
Ok, I managed to do it by uploading first BOOT_UP_KF01JC00014V2.4 and then DR06_16S200JC03_V2.0.0_T2_V_R.
Hey there, can u pls share the red node with the copy funktion so i can use your working construct? my battery looks similar to yours. that would be wonderful. thx.I'm new in this forum. And this thread was very helpful to me. By that I'd like to share my Node-RED code:
View attachment 133159View attachment 133160
I'm using three Pylontech batteries. By that I'm sending three commands:
