Rednecktek
Solar Wizard
So after my experiences with JK, I'm not using them anymore so I need recommendations on different brands of BMS.
I need:
4s and 8s versions (I work with both)
120+ amps continuous
Bluetooth
Low temp protection
Heater function/control
I don't think such a beast exists lower than 16s but I figured I'd ask.
Bonus points if someone can recommend a source for 120-160a DC breakers that DON'T require a DIN rail and I can mount through a battery box face plate. The smallest thing I've found was a 160a industrial breaker that I used in my battery build but is overkill. Smaller than that seems to top off at 50a. DIN rail breakers like the Chixi aren't going to work, I need the terminals need to be on the back and holes I can put screws through.
Anything out there that doesn't cost "What company are you with?" Moneys.
I need:
Bluetooth
Low temp protection
