Do BMS systems all work the same or could it be unclear when they are doing their job of protecting the battery?
I ask because I keep hearing about restarting the BMS after an overcurrent or improper battery voltage. Attach a battery charger to get it running again etc.
I have overused a battery on the bench a few times where I check the battery and it might read 3V. If I leave it alone, it recharges the next day when the sun comes up. I'm not using a charger so no restart is required. I don't understand this, did the BMS do that or not? How would you know?
