MullerEnergy-Australia
- Dec 10, 2020
- 95
Before I go reinventing the wheel, I thought I'd use the hive brain to make sure I'm not missing something obvious!
So we're developing a hybrid starter battery that uses super caps to start the car and LiFePO4 cells to ensure the caps are charged. However, we also have a second low-voltage disconnect that will disconnect the BMS from the caps so that the battery can't accidentally be drained (currently we've got another circuit board to do this, but this could be integrated into the BMS).
However when you enable the discharge again, the current flow from the say 12.6V battery to the flat super caps is extremely high, causing issues. So what I want to do is to implement a PWM functionality into a BMS and use the MOSFETs to do the switching. Assuming that the MOSFETs can be switched quickly enough (I haven't checked this), I think the BMS should have all the hardware required to also act as a PWM.
However I can't find a single BMS that seems to currently do this, which I actually find a little bit strange. Am I not looking in the right places or will I have to have a BMS designed from scratch to accomplish this?
Thanks!
Thanks!
