sailordave2929
- Sep 11, 2020
- 1
Thank you for having me in the group. First time posters so go easy. On our sailboat we currently have lead acid batteries, but I'm upgrading to lithiums. I'll quickly give some of my requirements. We use about 80 to 100 AH per day at 12 volts and our largest load is the windlass at 1000 watts at 12 volts. Our current solar is inadequate at 140 watts and this winter we'll be upping that to 300 watts with the potential to go to 500 watts if needed.
My question for a new setup is more with the BMS and that startup load for the windlass motor. The amp draw is going to be around 80 amps continuous once it's up and running, but on start up that could be 2 to 3 times that amount and will that trip say a 200 amp BMS or what size BMS would you guys recommend? There might also be the case of needing to start the engine with the main house banks which i believe is about a 150 AMPs. My other option is to wire the windlass to the lead acid starting battery that i'll have in the system which will be tied into the alternator. The total capacity of the new battery bank will be around 400 AH at 12 volts. Thank you.
