buckeyestargazer
I'm pretty new to DIY LiFePO4 battery builds and am looking for a little advice regarding an enclosure. I intend to 3D print a box for a 4S EVE LF230 12v battery (from Docan) with Daly BMS. The basic idea is to have a thick top and bottom frame with thinner side panels that basically just serve to enclose the battery.
First off, is this advisable in the first place?
Second, how important is it to clamp the cells together? If it is important, how tightly? Will a thick plastic frame on top and bottom suffice, or does it need to be stronger than that, i.e. 1/4" threaded rod and nuts in a wood or metal structure?
I intend to design the box so there is an air gap or insulated gap between the BMS and battery cells, and also some insulation around the cells. Also, I'll make sure the terminals are protected.
What else should I consider as I design the box?
