Building a battery pack
I’m ready to build my battery pack (24s 78ah LiFePo4 for a 72 volt system for an EV) and have a couple of safety-related questions before I started. I’ve read Micah Toll’s book on how to build batteries and also watched many videos on YouTube, but I want to verify a few things before I start. Here’s by list:
I’d rather ask obvious questions and be safe to make other mistakes! Thanks.
- Setting up for top balancing: I have a 0-30 volt battery charger and interconnects rated for 105A. I’ve seen Will Prowse use what appears to be a regular metal ratchet set to attach the nuts/bolts to the battery. He says in a video that he has a “composite” ratchet. I can’t seem to find those. I do have Class 0 & 00 rated gloves. I’d use a regular ratchet. Is this solution adequate?
- When taking apart this top balancing setup I’ll disassemble it using the same tools. I know from working on vehicles you should remove the negative first. Same thing applies here?
- Assembling in series: I have a method to compress them in a custom electrically isolated box. I will use the same tools. Any cautions here?
- Are there any issues with touching the insulated part of the interconnects when they are on the cells?
