Building a LiFePo4 battery to work with a SunSynk hybrid ECCO 5kw inverter.
rich4
If I use a JBD 200A 48v BMS along with 16x 280Ah EVE LiFePo4 cells, will it talk to a Sunsynk ECCO 5kw hybrid inverter? I assume it has to pretend to be a Pylontech?
Using 280Ah cells means it won't be a standard Pylontech battery type, so will that be a problem?
I really want to build a battery with around 14-15kWh of storage and using 280Ah cells means just one big battery unit instead of 3 smaller capacity units in series, so less BMS's and case hardware to buy.
I'm assuming a 200A BMS will be more than man enough for a 5kw inverter, which has a max battery current of 120A in and out.
In the UK, 16x 280Ah grade A EVE cells and a JBD 200A BMS will cost about £2500 plus a case, wiring, connectors, circuit breaker etc, so hopefully £2750 ish for 14kWh. Seems like a great deal, IF it works properly with a SunSynk inverter!
Cheers!
no it will not talk to the sunsynk.
there are a bunch of bms's that do, both commercial ( pacebms, seplos bms and i believe jbd is commning out with a server rack.bms) and a full diy solution ( diybms by stewart pittaway)
Hi @houseofancients, I am about to change my BMS because it does not communicate with my Sunsynk inverter.
Please could you confirm that Daly BMS communicate with Sunsynk without man-in-in the-middle?
It will not..
Look at seplos, pacebms they work 100% sure
Jkserver BMS is still having issues as far as I know, but may work in the future
What BMS are you currently using ?
