I know when you connect two batteries in parallel, they should be the same voltage, and you should verify they are at roughly the same state of charge so there isn't a huge inrush of current from one battery to another. In my research on this, it seems that the voltage is crucial, but state of charge isn't necessarily a big problem?
My question concerns using bus bars and connecting batteries with a dissimilar capacity.
If you have quality external bus bars, rated for 500 amps, and you connect two batteries of the same voltage, (say they're both at 13.2v) but one of those batteries has a capacity of 100ah and the other has a capacity of 200ah, will they still attempt to balance out their state of charge? Is the common advice to only connect batteries in parallel if they are the same voltage and similar capacity still applicable, if those batteries are connected to external bus bars and not directly to one another? Is that a distinction without a difference?
